weird weird behavior - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-30-2012, 03:17 PM Thread Starter
My 2000 f250 has never given me issue til this weekend it did something really weird. I went on a camping trip this weekend and had about 5 miles of bumpy dirt road to travel.. multiple times on this road my truck would do the following
Foot on gas everything working fine then sudden loss of power but it doesnt die... engine idles even if my foot is on the gas it sounds like a healthy idle.. dash lights come on "check engine" "wait to start" all of that stuff lights up... dash looks like the key is in the aux position... few seconds of all this and then truck comes back to life... power is back, lights leave, like nothing happened... whats going on? It did it only on this bumpy road except for one time just as i got off the bumpy road onto pavement it did it then... my thoughts are something electrical? i have since made sure my tuner had good connection. has anybody had this before? has not done it since last saturday morning
2000 ford f-250 leveled off, crew cab, headlight upgrade, gauges; pyro, boost, tranny. 6637 intake. 06 lariat dash/seats/interior. DP tuned. A dash of this, a dash of that
Motormorgan is offline
post #2 of 7 Old 07-30-2012, 03:59 PM
Quoted: 156 Post(s)
Feedback Score: 3 reviews
Have you checked the OD wires in the column for chafing?
Have a look at this link...
https://b7445ba3-a-62cb3a1a-s-sites....attredirects=0
NoRalPh is offline
post #3 of 7 Old 07-30-2012, 05:00 PM Thread Starter
never heard of that before. awesome link, ill look at that for sure! thanks!
post #4 of 7 Old 07-30-2012, 06:10 PM
This is how my issue started about 5-6 years ago. But now the issue is getting very bad. my truck is a 6 speed though. check out my thread "truck cuts off/hesitation". do you have any other issues. have you replaced anything on your truck.
I have heard of loose ground wire causing something similar to this
Good luck on finding out your problem.
BRAD6160 is offline
post #5 of 7 Old 08-01-2012, 07:38 AM
I have had this happen on 2 7.3ls. Take your fuel pedal assy out and cleaned the idle switch with contact cleaner and work the switch while you are spraying the cleaner. You will have the idle switch and the throttle position sensor on the assy. When mime acted up, it would go to idle, no power and just the CEL would come on, no other abnormal dash lights.
E99 F350 CC DRW AT
scarlson is offline
post #6 of 7 Old 08-01-2012, 08:35 AM Thread Starter
UPDATE: It hasn't done this again in the last week but I've looked for anything loose because its acting like a short. I was able to tighten down the bold holding the wiring harness to my pcm.. I was able to tighten it quite a bit, way more than I would like to admit. Does it sound like that could be the culprit or just a coincidence?
post #7 of 7 Old 08-23-2012, 08:11 AM
when mine did that it was the pedal assembly, I replaced it with an autozone/checker part and it was good for a short period of time and then wen south really quick in only a couple of days. I replaced that one with the ford one and problem has never come back. I have learned that replacing electronics on our trucks the best bet is go with OEM.
azroundboy is offline
