2001 7.3 turbo question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-29-2012, 07:27 AM Thread Starter
I have the 01 7.3l F350 quadcab with 175,000 miles. Lately the lag from start is getting worse and I cannot hear the turbo whistle hardly at all. I also cannot hear my wastegate. Does this mean my turbo and waste gate are going out? The lag is pretty big if I step on it but a few seconds later the turbo does kick in and has power up to 12psi. I want to hear my turbo whistle. if it needs to be replaced what turbo would you all recommend? and should the waste gate be done at the same time? thanks for your expert advise.
Frank.
DuneTigger is offline
post #2 of 8 Old 07-29-2012, 08:12 AM
Guns & Powerstroke's
HillClimber350's Avatar
Do you have a boost leak?
2001 F-250 Platinum Edition
BTS Trans, 6.0L Cooler, DP Tuner, AFE Stage 2 Intake, 4" turbo back, Bean's 1.0 housing, A/C mod, Billet T-Stat Housing with 203* T-Stat
HillClimber350 is offline
post #3 of 8 Old 07-29-2012, 12:19 PM Thread Starter
I do not know if I have a boost leak. I know there is always oily dirt on top of the turbo tubes near the Y. I cleaned them once and they are dirty again.
Frank
post #4 of 8 Old 07-29-2012, 12:29 PM
Leak at the up pipes.
ToddOH43 is offline
post #5 of 8 Old 07-29-2012, 12:34 PM Thread Starter
I am a bit new to a diesel so I do not know what the up pipes are, sorry. I only had this truck for two years and it is my first diesel.
Frank
post #6 of 8 Old 07-29-2012, 12:50 PM
Frank
The up pipes are the pipes that come off each exhaust manifold to move the exhaust gases to the turbo. Pretty common for them to leak.
ToddOH43 is offline
post #7 of 8 Old 07-29-2012, 12:51 PM
Good chance leaking there on the intake plenums pull them off clean all the oil off and then reinstall make sure good and tight.
post #8 of 8 Old 07-29-2012, 01:20 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
you will notice a boost leak at the uppipes if there is black soot around them....
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
Tags
7.3l powerstroke , f350 7.3 , super duty , turbo
