brake pedal on the floor - Ford Powerstroke Diesel Forum
Old 06-27-2012, 02:06 PM
Today while driving my brake pedal went straight to the floor even when the truck is turned off it still goes whole way to floor I was think maybe a bad booster but I'm not exactly sure. Please help its a 2000 7.3
Old 06-27-2012, 02:15 PM
Is your fluid full? Any leaks at the Master cylinder or any of the wheels? Have you checked the flex lines going to the front wheels to see if they are split?
I'm thinking it could be a master cylinder or any of the above. The system should hold even if the truck is off.
Old 06-27-2012, 02:28 PM
Fluid is full and no I didn't check any of the above will do that though
Old 06-27-2012, 02:31 PM
And there's no sign of leaking on the wheels
Old 06-28-2012, 01:12 PM
Anyone else have any suggestiond
Old 06-28-2012, 04:02 PM
If its not leaking I would lean towards the master cylinder, pop a line at one of your tires and have some one pump the brakes no fluid pressure then it's your master cylinder.
Old 06-28-2012, 04:07 PM
I pulled left rear wheels off and there was brake fluid all over the inside of my inner wheel I'm leaning towards caliper cuz rotor is wavy and destroyed and i did feel it dragging for a couple days and didn't think anything of it at first now guess the pistons in caliper ain't working. Does this sound like a possibility
Old 06-28-2012, 04:42 PM
That is your problem, comPlete brake job and you will be as good as new
Old 06-28-2012, 05:51 PM
Thanks gonna get that fixed asap
