Cruise Control Disengages
I have a problem on one particular road where cruise control disengages without me touching the brake pedal.
Its admittedly a sealed but bumpy winding section of road. On the new freeway which is smooth as - I can go for maybe an hour before it will occasionally just disengage cruise control by itself - whereas on the bumpy road it happens every few kms. Could it be that the break pedal moves a little by itself with the bumps and the disconnect sensor is too finely set? Is it an easy fix? Maybe there's something else? Does it work by maybe a dirty sensor on the tail shaft that counts RPM'S to maintain the speed or something? Hoping this is something simple...(and cheap) that I can rectify myself. Thanks in advance! |
Same problem with Cruise Control disengaging !!!
It began with the cruise disengaging every so often, then I noticed that when I would hit a bump in the road, it would disengage. Now, I can't get it to engage. Looking forward to your thoughts. So for, I have been able to fix or replace any problem that I came across by looking it up on the forum
figure out a way to monitor your brake lights. if they are on when your trying to engage cruise control its probably a bad brake pedal switch.
Idk if its anything like my other ford, but IIRC almost all cruise controls are held by vacuum..
you could possibly have a leak in a line somewhere that would open up just enough with a bump or something and over time, grew causing your no cruise issue. Sent from my DROIDX using AutoGuide.Com Free App |
its probably your brake pedal switch needs adjusting
Take ur psd to ford theres a recal for that exact problem... Ill try to get the recall number... But they can look it up by your vin... Y worry let them fix it... fyi im pretty sure diesels dont use vacum... Lol
Sent from my SPH-D710 using AutoGuide.Com Free App |
Ahh yes but as i said diesels dont have a vacum system i dont think....
some diesels have a vacuum pump but thats just for the blend doors in the a/c n heat
