Horrible fuel mileage on e99 - Ford Powerstroke Diesel Forum
Old 06-07-2012, 05:04 PM
spool up that turbo!!
A friend of mine has an early 99 7.3 auto eclb no lift all stock except gauges his fuel mileage dropped to about 9.8-10.5 mpg in the last couple weeks my cclb with 35's and tunes can get 18 freeway
Now we changed every filter fresh oil all that stuff no codes are being thrown but anybody know where to start with this problem
Old 06-07-2012, 05:10 PM
Send a message via AIM to White7.3stroker
Sliders on his brakes may not be releasing? Its a idea i dont know if it helps or not
Sent from my DROID X2
Old 06-07-2012, 05:17 PM
He just did all his brakes not long ago because a caliper did hang out but it's a place to start
Old 06-08-2012, 04:14 AM
When I had a bad milage issue a few years back it was the turbo. The prop bearing was pretty much shot, so there was hardly no boost and it was taking 1800-2000 rpm before the turbo would even begin to spool up. The engine would compensate by dumping more fuel. After I rebuilt the turbo, my economy literally doubled on highway.
Old 06-08-2012, 04:26 AM
MAP sensor, EBP sensor, BARO even maybe. ICP.
Old 06-08-2012, 10:00 AM
What's baro? And can all these be cleaned in re installed?
Old 06-08-2012, 02:59 PM
BARO sensor senses barometric pressure. I just googled 7.3 baro sensor and found it's only a real one E99. Maybe it isn't a big deal.
MAP can't be cleaned. It either has a cracked/loose boost tube going to it from the spider.
EBP can be cleaned. - Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
ICP - Usually it'd run bad if it actually was bad but it's worth a shot.
Old 06-08-2012, 05:00 PM
Yeah that's why I kinda ruled out icp cause it still runs like a champ just crappy fuel mileage but you never know
Old 06-08-2012, 07:16 PM
try unplugging the ebpv and run it like that for a few tanks and see if it helps, then if it does, just leave unplugged lol
Old 06-09-2012, 07:55 PM
I would say EBPS/tube, get them cleaned, possibly IPR. If there is any oil in the icp, then it will need replacing; there should not be any oil in it.
if the truck still runs great its probably not the ebpv.
I say if it just started, then its a sensor of some sort. I replaced my IPR, ICP and cps, I am getting the best mileage ever now. Still nothing compared to others but good for me. 14ish city/ a little over 17 hwy. Most I got before was 12.5 no matter what. I recently switched to PHP chip/tunes, so thay may have helped too.
