help!!! new terminator t500 now want start
Changed hpop and lines on my 02 yesterday an now cannot get it to start cranked on it probably 30 min or more. I changed oil at same time. Filled resivoir. Tried unhooking icp ipr buzz tested injectors has90 psi of fuel pressure an ice jumps to 2000when cranking. I switched lines around. Double an triple checked all connections. Im not getting any smoke while cranking. Out of ideas.
nobody ......
i now this might sound like a dumb question, is the gear for the hpop on there straight and bolt tight? also did you change the ipr when changing the pump?
yes. if it wasnt it would build psi
sounds like an ipr to me, you didnt answer before did you put a new ipr with the pump? because ive put in new pumps and wont start with the same icp pressure because i piece of dirt gets into the ipr
Swapped ipr, tried huff of starting fluid still nothing.did get lil smoke with starting fluid is all
It will start an run on either but want stay running without it.
Checked gear bolt... Tight, torqued at 100ft lb, checked resivoir again. Full.
check your UVCH to make sure you didn't know something loose why you were in there I have heard of that happening before
