Boost Pipes look Dirty - Ford Powerstroke Diesel Forum
Old 09-30-2007, 10:16 AM
My boost pipes look dirty...espeially right where the foiled side attatches to the intercooler. Does this mean I have a leak, and if I do, how can I fix it?
Old 09-30-2007, 10:35 AM
are you talking about the buildup around the boots? if so, that is completely normal
Old 09-30-2007, 10:48 AM
Yes, there is a heck of a build up around the boots
Old 09-30-2007, 10:50 AM
Isn't the CCV mod supposed to help/eliminate that? I thought some of it at least
Old 09-30-2007, 11:03 AM
I guess it should.... I haven't done the CCV mod..
Old 09-30-2007, 11:06 AM
I just did it after cleaning all the crud off and painting the IC pipes, I had alot of buildup, hoping it helps, I thought that was one of the main reason's for doing it.
Old 09-30-2007, 11:08 AM
I think it is.. but I have no idea if it really helps anything or not -- but in theory it should
Old 09-30-2007, 11:16 AM
After blowing off the hose closest to the turbo i did the CCV mod and it has cured the problem of oily hoses/tubes, very easy mod to do
Old 09-30-2007, 11:17 AM
Well there's the answer I think he was looking for I may have to do that someday..
cool deal!
Old 09-30-2007, 09:56 PM
The build up is from the CCV. If you do the CCV mod then you will be clean and pretty instead of dirty and ugly.
