check engine light problems - Ford Powerstroke Diesel Forum
Old 05-05-2012, 03:44 PM
Okay i have a 2000 7.3 auto. Every time i really get on it my check engine light comes on, i hook my tuner up and read the trouble codes and the code "inject press above/below ". the only way iv found is to clear the code to make the light go off. any one else out there have this problem?????????????
Old 05-05-2012, 03:54 PM
Tons of times.
Do you have a chip?
How HEUI works and best to convert - Read on how your motor works.
What's more than likely happening is that when you go WOT, the HPOP can't keep up with what the PCM is requesting, and that throws a code.
Old 05-05-2012, 04:06 PM
i just have the edge evolution tuner
Old 05-05-2012, 04:26 PM
That's it then. HPOP can't keep up with the desired ICP.
Old 05-05-2012, 07:05 PM
is there anything that i can do to keep the light from coming on or just not worry about it ??????
Old 05-05-2012, 07:16 PM
Powerstroke Techie
Buy a better hpop. That's the only way to get around it and get the full potential out of your chip.
Old 05-05-2012, 07:26 PM
what would i be looking for ? how much ?
Old 05-06-2012, 07:42 AM
Powerstroke Techie
The two most common ones that I know of are the terminator for about $500 or the adrenaline that runs about $700.
