Ok, here is my problem. Driving like normal, the truck is running just fine. Out of nowhere the check engine light pops on (kinda irrelevant, I know) and the rpm's drop to seemingly zero. The truck coughs and sputters and then the rpm's come back to normal. This is happening repeatedly until I pull over and turn the truck off. Restart the truck and it runs just like normal until it happens again. The problem started last Friday and has done it (3) times so far. It also stalled for no apparent reason on Saturday. I have no idea what could be causing this and wanted some advice before I take it to the shop.
Truck specs: 2000 7.3l with 157k miles, stock except for intake, Turbo-back 4" and a TS performance tuner. Please let me know if this sounds at all familiar, I know its vague, but thats really the only signs of the issue. Thanks. |
I can't think of anything more relevant ![]() Go get your truck scanned and find out what code was set when the light came on. Nothing will point you in the right direction better, the light came on for a reason, something important was out-of-spec that cause the engine to lose power. Find out what that was by the stored code. Unfortunately, you're going to have to find someone with a professional scanner (not a cheap, generic, scanner like the Auto Parts Stores use) to retrieve codes because are trucks aren't, strictly, OBD-II
Sorry, only irrelevant because I don't know the codes it pulled. Taking it to the shop after work to get it checked out. Thanks!
