Troubleshooting glow plug stuff
Well I am still working on getting this truck started and I started troubleshooting the glow plug stuff...I tested the relay yesterday and it seemed to work fine. I followed the following instructions to test the glow plug stuff..
To check Glow Plugs. · Remove the electrical connector on the inboard side of valve cover at the gasket. Press down on the top of the connector latch and pry gently with a screwdriver. Photo of disconnecting one and another Photo of it loose. · There will be 9 pins on the valve cover gasket where you removed the connector. The two pins furthest forward and the two pins furthest back are for your glow plugs. · With your multimeter set to resistance (ohms) and low range (single digits) if not autoranging, clip the negative (black) lead to a good ground point. · Probe each of the 4 outer pins individually with the positive (red) lead, noting the resistance. Good glow plugs will have a resistance between 0.6 and 2 ohms. If you get infinite resistance on any glow plug, that one is either bad or the connector under the valve cover has come loose. this info was from this link to give credit where i got it from... Troubleshooting GPR & GP's so i went and did the resistance tests and here are my results passenger side starting at connector towards the radiator ending at connector on the firewall side. .6 ohms 49.57m ohms 42.60m ohms open loop driver side starting at connector towards the radiator ending at connector on the firewall side. open loop 63.9k ohms open loop .7 Well houston we have a problem...i called the guy i bought it from and he said he bought the glow plugs from O'Reillys back in july...he said replaced the glow plugs but not the harness... I have not popped the covers yet...it is windy here today and dont want to get crap under them... would you replace just the harness or glow plugs and harness...what be your thoughts? thanks gangs for any insite |
Which GP brand did he use? If they were anything but MotorCraft (Beru) I'd replace them. Others have been known to have the tip swell and stick/break off in the head upon the next removal.
ok...i further troubleshot the glow plugs and found this out. I pull the electrical plugs off the glow plugs and did the ohm test there...from ground to the top of the glow plug i found the readings to be the same as from the outer plug. so it seems the glow plugs are junk...found a new set of 8 and ordered them...two did test good but made sense to replace all 8 at the same time. so we are getting there.
