parked on hill no start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-05-2012, 08:57 PM Thread Starter
Parked on a steep driveway for a few hours, started truck and it ran for a minute and died, let it roll down hill and checked h pop no oil in it,scanned it no codes finally pushed it out on street where it was flat and level let it set a few hours and hpop had oil in it, all this was over a period of three days of cranking but no start.to shorten story it would not start until it was off the hill why did oil drain out of hpop?
03 7.3 crewcab dually,6637 filter
benzo is offline
post #2 of 5 Old 04-05-2012, 09:01 PM
jesilvas's Avatar
Quoted: 2 Post(s)
What truck is this?
Obvious things might be low oil, or the little check valve springs in the end of the hpo lines.
My Samsung SGH-I997 made me send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 5 Old 04-05-2012, 09:07 PM Thread Starter
2003 7.3 dually oil was not low 322000 miles runs great,tell me more about check valve springs.
benzo is offline
post #4 of 5 Old 04-05-2012, 09:10 PM
jesilvas's Avatar
Quoted: 2 Post(s)
At the ends of the hpo lines, at the fitting to the heads, I've seen pictures of these springs that are basically check valves that keep thee pressure in the hpo rail.
But I guess that wouldn't explain the reservoir draining
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 5 Old 04-05-2012, 09:19 PM Thread Starter
I could not touch oil with an allen wrench.
benzo is offline
