Need PCM Pins/connector #s diagram - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-23-2012, 11:35 AM Thread Starter
Houstonvett's Avatar
Got the P1670 code in a new re-built 7.3 engine. Getting what sounds like a fuel knock after the engine warms up in the driver's side bank. Getting no EF signal so I need to run down this problem by checking out the wires in the circuit for the IDM/PCM setup first.
I lost my numbers diagram of the PCM connector so I can't test the wires in the circuit and make sure they are good. Anyone on the board have a diagram of the PCM connector that shows the pin location/numbering sequence that Ford used for the 7.3s? TIA.
Houstonvett is offline
post #2 of 4 Old 03-23-2012, 12:50 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
I've got this, not sure if the "mid '01 electrical revision" effected the PCM pin-out (you didn't include the yr. of your truck ) But this is for a 2000.
NoRalPh is offline
post #3 of 4 Old 03-23-2012, 01:10 PM Thread Starter
TNX a million there NoRalPh for the picture of the PCM connector. Do you happen to have a Vector file for that you can Email or just that raster file you posted? Mine is a 2000 truck, so that worked out perfect. Thanks again for that help NoRalPh.
post #4 of 4 Old 03-24-2012, 06:12 AM
Quoted: 157 Post(s)
I'm afraid that's all I have, But if you right-click it and Save Image then you can open it with the Windows Viewer and it's still pretty legible when expanded. I think it's actually like 430K.
NoRalPh is offline
