00 F250 door locks
Can somebody help me with my problem.
All 4 door locks went out at the same time. I can push the clicker and they go up a little and then back down. I can see 1 or 2 going out but all 4 at once. Where is a good place to buy new door locks. Please unlock my doors!!!! |
ohhhh.. I am pretty sure that there is either a service bulletin on those (all 4 of mine were replaced at the dealer before I bought it) or they just were one of the things that are bad on these trucks... for some reason they break..but I'm not sure why its all at once...
they are the door lockactuators they are very common on these trucks and all of mine went.
Door Lock actuators
All four of mine went out at the same time as well. Check out this thread. If you want to save money and fix them it works, I fixed mine and alot of guys have done this mod. Its not real easy, but its not difficult either. pm me if you got questions, maybe I can help you out. The other alternative is to buy new actuators, and they're expensive and you still have to take your door apart. Might as well fix for free. |
Look here....Pictures ...... Scroll down a bit.....
Thanks Fellas I will try and fix them When I get home
did ford do an upgrade to prevent this on later years or do I have this problem to look forward to?
Thanks fellas finally got around to fixing the locks all work fine.
Good to hear bud
and raj, I've only heard of the problem on the 00 & 01 & poss 02models -- but I could be wrong |
