Abs problems - Ford Powerstroke Diesel Forum
post #1 of 24 Old 03-21-2012, 05:06 PM Thread Starter
Abs problems
My truck is an 01 F250 7.3PSD. A few weeks ago the abs light started kinda fading in and out and then stay on for a while the go away then come back then fade again. At first I thought it was simply a ground issue. I inspected all the wires and connectors I could see, even check the wires to ground looking for shorts, didn't find anything wrong.
Then last week the infamous Speedo signal stopped and o/d light would flash and the abs light stayed on constant. After reading a bunch on here I decided it must be the rear speed sensor. So I pulled it inspected the tone ring while I had it out through the hole and it looked good, the sensor ohm'd out ok, I did note metal shavings on the sensor but they went bad at all. I replaced the sensor anyway, what's 13 bucks if it might fix it.
Sure enough the symptoms didn't disappear. So after more reading on here, this past weekend I changed the rear diff oil. And that fixed everything. Then on my test drive about 20 min in the abs light started coming on the Speedo and o/d light worked normal.
So it's fixed- ish, or so I thought. Today on my way home from work the Speedo stopped and o/d light came back flashing.
Sorry for the long post but I'm so frustrated with this thing and really could use some help.
Thanks in advance for any help you can provide,
Andy
Sent from my C771 using AutoGuide.com App
R3DN3CK is offline
post #2 of 24 Old 03-26-2012, 03:57 PM Thread Starter
Sent from my C771 using AutoGuide.Com Free App
R3DN3CK is offline
post #3 of 24 Old 03-27-2012, 04:33 AM
zrain25's Avatar
Rear abs sensor. My abs light goes on sometimes I was told to replace that sensor it's on top of the rear diff
Early 99 201,000 miles. Extra spring up front leveled, 4 in turbo back to 6 in tip, 6637, glow shift gauges, dp tuner, kicker speakers, alpine head unit and amp, kicker sub, extang tonneau, bedliner bumpers grill, flares, and rockers, 33in toyo mt, 18in xd monsters, 05 Harley lights, recon tails and line of fire, 20% tint
zrain25 is offline
post #4 of 24 Old 04-02-2012, 07:45 PM
Wildfire532FB's Avatar
I am having ABS issues too. Mine just came on though. I took it to FORD to get scanned and they got the code for the rear speed sensor and they replaced that but the ABS light stayed on and they couldn't communicate with my ABS module so they said my ABS module is bad and its a 545 dollar part Looking for a cheaper one online, have you had your ABS scanned?
2003 F350 Crew Cab 7.3L
- AFE Stage III Intake
- 4" Exhaust
- Goose neck setup
- Billet Grill
- 3 gauge A-Arm Cluster (Trans Temp, Boost, Pyro)
- DP F8 Chip
- Banks Big Head
Wildfire532FB is offline
post #5 of 24 Old 04-02-2012, 09:48 PM Thread Starter
My cousin has a scan computer and it reads abs, but it gave me the can not communicate also. So I was assuming the abs module was bad but don't have 500 bucks to replace it. And would be super pissed if it doesn't work
R3DN3CK is offline
post #6 of 24 Old 04-03-2012, 05:47 AM
Yeah that's why i am holding off.
So you replaced your Rear Speed Control Sensor and your abs light is still on?
- 4" Exhaust
- Goose neck setup
- Billet Grill
- DP F8 Chip
- Banks Big Head
post #7 of 24 Old 04-03-2012, 10:13 PM Thread Starter
Yeah after I replaced the sensor my light was still on. My scanner couldn't communicate either. So I disconnected the batteries for 15 min or so. And that turned the light off. Everything worked great for about 20 miles, then every symptom I had returned. So I'm leaning to the module.
R3DN3CK is offline
post #8 of 24 Old 04-04-2012, 05:11 PM
Did your scanner communicate before you replaced the sensor?
I am actually getting no symptoms, truck drives and brakes normally just my abs light is on.
- 4" Exhaust
- Goose neck setup
- Billet Grill
- DP F8 Chip
- Banks Big Head
post #9 of 24 Old 04-04-2012, 09:32 PM Thread Starter
O don't know if it did or not. When the light came on, it would not communicate. I never scanned the abs before so I don't know that its not the scanner, but I know I have typical symptoms of a rear vss but after replacing that and it didn't fix it I'm leaning to the control module as that's the only other thing in common with all symptoms.
As far as your light being on are replacing the rear vss, did you disconnect the neg battery cables for 10 min or so to reset the computer and the light should turn off. The module tends to store codes even after the problem is fixed.
R3DN3CK is offline
post #10 of 24 Old 04-05-2012, 03:00 AM
Turbostang500's Avatar
I don't know if this helps but I do think the speedo signal comes from the OSS on top of the trans. Don't hold me to that though, but you might want to inspect that wiring and maybe test/replace that sensor.
Front one (on left) is the TSS and the rear one (on right) is the OSS.
Hope this helps some.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
