battery keeps dieing - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-21-2012, 08:47 AM Thread Starter
vms305's Avatar
with fully charged batteries and a good alternator, by the time the glow plug light is out the truck will only turn over a few times. This happens after i let it sit for a few days and i dont plug it in since its been warm. Theres no problems that i know of beside a going bad window button assemble and the od push button isnt lighting up.
Any idea's
vms305 is offline
post #2 of 8 Old 03-21-2012, 08:50 AM
fordpwrstroke7's Avatar
Have you hooked up any new accessories or lights lately? If so, there could be a slow and steady draw that needs to be fixed.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #3 of 8 Old 03-21-2012, 10:53 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
I don't know how you're determining the state of your batteries charge, but they can be "fully charged" and have little capacity (because they're bad....)
Take them out, fully charge them again, and have them Load Tested at a High Rate to know what the condition of those batteries really are!
NoRalPh is offline
post #4 of 8 Old 03-21-2012, 12:48 PM
DrewGerhan's Avatar
Second the load test. They might show full charge, but fall flat on their faces when needed.
Sent from my DROIDX using AutoGuide.com App
E99 7.3L ECLB 4x4
140,000 miles
4" lift on 33s
6637 Filter
5" Diamond Eye
PHP Phoenix
Quad Gauge Pod
05-07 Headlights
DDM 55w 10,000K HIDs
Harpooned
800w Pioneer amp and 10" Kicker sub
Avital 5303 Remote Start and Alarm
DrewGerhan is offline
post #5 of 8 Old 03-21-2012, 05:52 PM Thread Starter
vms305's Avatar
I took them to advance auto and they did there test on them. They where new in late 2008. 2009
vms305 is offline
post #6 of 8 Old 03-23-2012, 04:17 PM
did they actually load test them? and did you get them to test your alternator too? if that was tested and good, then start tracing ground wires of anything you might have added lately, then fuses.
seven_point_three is offline
post #7 of 8 Old 03-23-2012, 04:36 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You say 'unless the block heater is plugged in.'
So, if it's plugged in, it's an easier start, and unplugged it's a hard/no start?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 8 Old 03-27-2012, 04:42 AM Thread Starter
vms305's Avatar
yes usally if its plugged in its easier to start. They tested them but i ain't sure if they load tested them Im assuming they didn't becuase the battery will charge to 100 but under cranking sometime is dies rather fast. No new lights nothing like that. But the one battery that has all the wires tieing into it the battery clamb is corroded half away. Fixing this isssue right now.
vms305 is offline
