Wait to start light issues. Not bowl heater - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-28-2012, 02:32 PM Thread Starter
My brother is having issues with his 01 250. It just randomly die from time to time and then will not crank. The wait to start light will not come on and it doesn't seem to be getting fuel. Then it seems to randomly just decide to come back on and the truck starts and runs fine for a while. Sometimes for a week sometimes for an hour.
We've unplugged the fuel heater(although it never blew a fuse), replaced the cam sensor, icp, ipr, and the PCM. Even put new grounds on the battery.
I'm at a loss. I think it must be a bad wire somewhere because sometimes it flickers but I don't know where to start looking.
Any ideas?
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #2 of 5 Old 02-28-2012, 02:39 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I'd think something loose. No WTS light is PCM usually since that's what controls it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 5 Old 02-28-2012, 02:41 PM
Powerstroke Techie
justinmix's Avatar
Hmm, if it's not turning on the wait to start light then the PCM must be losing power intermittently. I'd be looking at PCM main powers and grounds, along with any PCM power relays. I'd also look over all battery connections and make sure all that's cleaned up.
Is it just an issue with starting it, or does it die on it's own after you have it running?
justinmix is offline
post #4 of 5 Old 02-29-2012, 03:45 AM Thread Starter
We changed the PCM to a brand new one from ford and still does the same thing.
Occasionally it will just die when running and not start. Sometimes it's parked and won't start. Then randomly it seems, it decides to start. Also when the light will not come on, the superchip will not establish a connection with the computer. When we were messing with the grounds one day the light came back on. So we changed the grounds on the battery and so far it's been working. We are going to go over the rest of te grounds and maybe add a few from body to frame just for the hell of it.
2000 F550 CC 2WD
Schnot is offline
post #5 of 5 Old 02-29-2012, 04:09 AM
Powerstroke Techie
justinmix's Avatar
Yeah, I'd do that, as well as check all fuses and relays for PCM power. Look for any signs of corrosion.
