HID Causing issues - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-27-2012, 06:44 PM Thread Starter
maddenjr's Avatar
Send a message via AIM to maddenjr
HID Causing issues
Ok so i put a set of HID's in my flat bed and now when i turn them on i get an abs and also if im cruising on the hwy with the cruise control on and i put the lights on it kicks the truck off cruise.... I have had HID's in every truck ive had and never seen this! I even swapped out another set of lights and still the same **** and now im annoyed
Spartan,Afe,Mbrp Delete with duals,Banks Intercooler,Custom CCV Mod,22.5 American Forces,Flo Pro egr delete,Lots of Strobes,Atomic Strobes,5%Tint and 20% Windshield Tint,B&W gooseneck,K3LA Train horns and some other goodies, Head studs and waste gate coming this spring
2001 F350 Flatbed/Car Hauler, Ext Cab,07 Front End w/Cowl Hood,SCT Tuned,MBRP Straight pipe
92 Mustang Lx Hatch X275 Drag Radial been low 7's
03 Cobra with a lil extra boost
maddenjr is offline
post #2 of 20 Old 02-28-2012, 06:26 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
I don't have cruise so, not sure what would happen with my HIDs. But, my ABS light comes on too (the ABS unit is Very close to the ballast) and I don't worry about it...
There's considerable voltage being delivered to the HID bulb and a lot of accompanying RF (Radio Frequency) that is confusing stuff and shouldn't be of much concern. Yea, kicking-out the cruise would be pain I can see. It might be possible to suppress some of the effects with Ferrite Beads. Others have solved their problems with the DPTuner board (where your truck actually DIES when you turn the headlights on!). Maybe you could either work it out, or learn to live with it
Oh yea, don't let anybody convince you it's the quality of the HIDs that are the problem, they ALL can do it. It has much more to do with the "sensitivity" of our trucks than the source of the RF....
NoRalPh is offline
post #3 of 20 Old 02-28-2012, 06:28 AM
What tuner are you running?
Jason, But you can call me Sir!!!
2001 F-350 CC Dually~Built and tuned by PHP~572/1161ft lbs fuel only~few LEDs here and there
GOPOWERHUNGRY.COM
Lowdown89 is offline
post #4 of 20 Old 02-28-2012, 07:58 AM Thread Starter
maddenjr's Avatar
Truck is stock right now but i have a Superchips for it just not in at the moment. Its a flat bed so im not concerned about it goin fast just has to be reliable Ive got a 6.4 thats pretty fast with some goodies and 2 mustangs
maddenjr is offline
post #5 of 20 Old 02-28-2012, 08:40 AM
Do you have a low beam only kit? Or is it a hi/low kit? I had this problem with my fog lights only when I DIDN'T run a relay harness to them...now my headlights didnt do it and just the fogs but when I pulled the fog switch the abs light would come on and the speedo would drop. The weird thing is, that every truck won't do it like that we put the same exact kit in my buddies fogs on his f250 and they work fine every time.. Like he stated above it's not the kits fault just some truck are weird.
GOPOWERHUNGRY.COM
post #6 of 20 Old 02-28-2012, 11:23 AM
audiocontr's Avatar
Cheapie HIDs from ebay are well known to do this. I removed mine and threw them away.
Nonconformist. Functionality over bling.
My three rules for 7.3l troubleshooting: 1) Replace CPS and keep a spare. 2) Replace FPR and know your fuel pressure. 3) Hook it to a scanner and check for codes.
audiocontr is offline
post #7 of 20 Old 02-28-2012, 12:41 PM
And let me guess you replaced them with some that came in a fancy metal box?
GOPOWERHUNGRY.COM
post #8 of 20 Old 02-28-2012, 05:47 PM Thread Starter
maddenjr's Avatar
Hahaha
maddenjr is offline
post #9 of 20 Old 02-28-2012, 05:49 PM
audiocontr's Avatar
Negative. All stock.
post #10 of 20 Old 02-28-2012, 05:50 PM Thread Starter
maddenjr's Avatar
I actually have a set of hi/low beams... They are all cheap pieces of crap! I havent found a good quality set of hid's yet and trust me id pay big money to get a real set of phillips if i could just to not have to deal with headaches! My 2010 F450 has been through i cant even tell you how many sets
maddenjr is offline
