2001 stalled when raining wont start new CPS and IDM
It all started when it would rain it would die sporadically when i would be idling or slowing down. when going down highway it seemed to die and start right back up on its own and jerk real hard as long as i was in the pedal. Also die when parked idling in the rain. I changer CPS, nothing changed. problem started to get worse and happened more and more. now sometimes I would try to start and it would crank and crank and i would have to push pedal for it to start. a few days later in the rain it died and wouldn't start again. No smoke from exhaust when cranking. just crank and crank. I changed the CPS again, and the IDM was replaced as it seemed to have water damage and the plug had moisture when i removed it. still wont start. Never had an issue when is was dry outside. maybe water was leaking into PCM and finally took a crap??? I don't know what else to do.
