99 F350 Power Steering Fluid - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-25-2012, 12:13 PM Thread Starter
About a month ago I noticed my power steering fluid had a milky color to it, so I flushed the system. Looked at the fluid today and it has milky color again.
Its only been a month since it was flushed. Anybody know what is causing the fluid to become milky?
Thanks
thall81 is offline
post #2 of 6 Old 02-25-2012, 12:42 PM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Are you using ATF?
Milky is usually a sign of water, That wouldn't be good
NoRalPh is online now
post #3 of 6 Old 02-25-2012, 04:19 PM Thread Starter
Yes, I am using ATF. Where would water be entering the system?
thall81 is offline
post #4 of 6 Old 02-25-2012, 07:15 PM Thread Starter
Would water enter from air in the system? Looks like a closed loop.
thall81 is offline
post #5 of 6 Old 02-25-2012, 08:21 PM
lug
lug's Avatar
Check the o-ring on the fill cap.
lug is offline
post #6 of 6 Old 02-25-2012, 08:24 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 4 Post(s)
It can only enter at the cap. Most of the system is pressurized ,so it would leak. Are you missing any part of the inner fender well. Water can splash up from the tire on to the cap.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is online now
