2000 F250
I am trying to work all of the bugs out of my truck and try and improve my MPG as well as have a reliable vehicle for years to come. Truck is a 2000 F250 xcab long bed 4x4 auto 181K. So far I have replaced EBP sensor and cleaned tube, replaced MAP sensor, replaced CPS with IH CPS, free up EBPV, tie wastegate closed for now(actuator will not hold), full service, and added 6637 filter, tightening all CAC piping no boost leaks, and no up pipe or manifold leaks. Was getting around 9 MPG now getting 11.5. I do not have gauges yet but was monitoring it on a Snap on Modis boost and all other functions seems to be right where they should be. I drove the truck a short distance today and the exhaust was red hot could barely touch it. Is this normal? Is it possible the muffler is clogged? Also the breaks are not hanging and the hubs are not locked. I would appreciate any info.
Is your exhaust factory? If yes, does it have a cat? Just trying to help ya out a little. If its all stock, I would recommend a 4inch turbo back. It'll let it breathe a lot better and give it a nice sound too.
Sent from my DROIDX using AutoGuide.com App |
Yeah it does have the factory exhaust no cat on it. I took the muffler off of it and put a straight in for now. Definately freed it up a bunch. I will put 4 inch on it soon.
Any others ideas I am stumped? Also the engine has seem to gotten really loud. I have taken the vc's off and checked the both harness, all rocker ams an injector hold downs, and all injectors all spitting oil equally. I cut the muffler off and straight piped it and took it for a ride with the modis on it and boost psi went to 21 psi, all other items looked good. The truck passes all KOEO, KOER, and cylinder contribution tests.
Rather odd. Maybe you're having injector problems.
Im stumped. I thought that maybe but it never smokes when your driving it. Only a puff when it's cold started after it sits overnight.
Ok so I was doing some more testing. For one my fuel pressure is good. Second my baro reading is 30 instead of 14.7 like it should be. My map and ebp read as they should. I the baro sensor is in the PCM on these truck is there any way the clean or recalibrate them or is my PCM bad? It says this is part of how they control the timing so this possibly could be a part of my problem. Any thoughts?
