99 No Start Codes
So here's what happened drove home from poconos 2hr drive fine
parked truck, took off tw chip from pcm needed to send to get reburnt, key may have been on.. plugged pcm back in bolted everything up.... next morning go to start truck sounds like it has no compression now i know a couple of these are probably from my chip but heres what i got P0472 P0107 P0123 P0381 P0603.... WTS light works oil pressure goes up after about 5 or 6 seconds of cranking. rpm's do not move... is it possible i fried the PCM..? I ran a buzz test and all sounded the same when cranking ICP pressure does not move, i drained the fuel bowl and filled it with diesel 911 noticed after several long cranks the diesel 911 is still in the fuel bowl, so no im wondering is it the fuel pump any ideas, thanks |
Did you disconnect batterys?
Sent from my PG86100 using AutoGuide.com App |
no i did not
Your probably looking at a PCM issue then , you must!! Always disconnect your batts!!,
well will do that.... guess im gonna look for a pcm probably a PMT1 since its' an e99
grabbed a PMT2 from the boneyard for 70 bucks runs like a charm just gotta get chip reburned
