OBD2 Power - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-20-2012, 06:35 AM Thread Starter
zROCK's Avatar
OBD2 Power
Im not getting any power to my obd2 port. I have power to the lighter but when i probe the port i get nothing?
zROCK is offline
post #2 of 7 Old 02-20-2012, 07:05 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
That's strange, you do get a WTS light when you first roll-on the key?
Where are you looking for power in the port? It's in one of the corners - right?
The pins all look good?
NoRalPh is offline
post #3 of 7 Old 02-20-2012, 07:08 AM Thread Starter
zROCK's Avatar
Woops i put this in the wrong year. My truck is a 95. I probed all the pins. All look good and all the lights are working fine
zROCK is offline
post #4 of 7 Old 02-20-2012, 07:38 AM
Quoted: 157 Post(s)
OK, I'm not sure why, there should be power of course, but let's back-up....
Are you having a problem? You're trying to connect with a scanner? What else is wrong?
NoRalPh is offline
post #5 of 7 Old 02-20-2012, 07:45 AM Thread Starter
zROCK's Avatar
Im looking at buying a used edge programmer.. Yes i know everyone will recomend a chip but im just looking for fuel econ not power. When i plug it in it will not power up. It works fine in the original truck.
zROCK is offline
post #6 of 7 Old 02-20-2012, 08:20 AM
Quoted: 157 Post(s)
Boy, I donno Next would be to start tracing the wire back and see where it's losing power. Or could be the Ground in the port too.
Pin #16 = (+)
Pin #4 = (-)
NoRalPh is offline
post #7 of 7 Old 05-04-2012, 12:42 AM
that is the bluetooth obdII I have. it will work on anything with that port. I use Torque also.
is an advance over obd1 in both adequacy and standardization.
This
came in two models
A and
B.
greatobd2 is offline
