CHANGED GLOW PLUGS AND... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-15-2012, 11:35 PM Thread Starter
Powerstwoke's Avatar
Question CHANGED GLOW PLUGS AND...
i changed the glow plugs in my 03 7.3 and now the truck has a very rough idle
(sometimes a lope idle) and the truck has no power when i hit the gas. the truck sounds very rough. i checked everything and everything is plugged in... what could have happened. its throwing the p1316 code on my edge cts. something with the injector? the injectors are only a couple years old????HELP lol
2003 Ford F-350 7.3 powerstroke Diesel Standard cab long box. White with 135,000 miles, EDGE CTS, 5% tint all around,DIY tymar, 5 inch straight pipe no muffler with 8 inch tip, whicked wheel, 2.5 inch front leveling kit, 33's, glow shift gauges, 2006 front end conversion, 2008 super duty tailgate, taillights, seats, bilstein 5100s, Zoodad mod, foil delete...reppin FORM ATHLETICS MMA more to come
Powerstwoke is offline
post #2 of 6 Old 02-15-2012, 11:47 PM
Quoted: 6 Post(s)
I googled the code and found a post on FTE
HELP P1316 code & Runs Rough?? - Ford Truck Enthusiasts Forums
1999 F-350 ECSB ZF6 4x4 Halfbreed:
Mods:
PHP Pheonix 6-Position Chip
Glowshift gauges (boost/egts/oil psi/fuel psi/oil temp/coolant temp/voltage
DIY 6637 Intake
5" Diamond Eye exhaust
05+ Harley Davidson Headlights
55w 5000K HIDs
Future Mods:
Shocker horns
SRP1.1
Irate turbo setup
S366
DIY fuel system with regulated return
and saving to build a mid 500hp rig.
stroker0920 is offline
post #3 of 6 Old 02-16-2012, 12:07 AM Thread Starter
I'm going to check that clip tomorrow just wanted to see what else you guys thought.
post #4 of 6 Old 02-16-2012, 12:12 AM
Quoted: 6 Post(s)
Google can be your friend sometimes lol
Mods:
DIY 6637 Intake
55w 5000K HIDs
Future Mods:
Shocker horns
SRP1.1
Irate turbo setup
S366
post #5 of 6 Old 02-16-2012, 12:19 AM Thread Starter
also anything else i should/can do while I'm under the valve covers again??
post #6 of 6 Old 02-16-2012, 12:20 AM
Quoted: 6 Post(s)
I'd just check the connections. mainly the main valve cover plugs
Mods:
DIY 6637 Intake
55w 5000K HIDs
Future Mods:
Shocker horns
SRP1.1
Irate turbo setup
S366
