Tire rub
On my powerstroke i have noticed my tire rubs only when turning sharp right on the passenger side. It is rubbing the front leafs. What would maybe cause this. Thanks
Your tires are wider than stock or you have an aftermarket wheel with a neg offset. Just make sure your brake lines aren't rubbing on your tire and safely secure them with heavy duty zip ties if they are rubbing.
Wide tires, higher offset wheels or possibly your pitman arm is aligned a little more towards that side.
Its not catching the plastic on your front bumper or in your fender well? Sent from my DROIDX using AutoGuide.com App |
Rubs just on one side? sounds like the axle itself is a little offset
yes just on 1 side on the leafs
