Jerry
I hope that I'm doing this right. There are no instructions for posting, so here goes. I have a 99 power stroke. This is the second time that I've gotten bad diesel fuel.
Each time this has happened, after 70 miles or so, the truck started running rough. Both times, I pulled the fuel tank and cleaned it thoroughly as well as the fuel filter. The fuel in the tank was a brown muddy consistency on bottom. The first time, I wound up putting it in the shop and the mechanic replaced two glow plugs and two injectors, the injector module, and filter housing at the tune of $4,033. This time I now have cleaned and replaced the fuel tank and filter. It turns over well, but I am not getting any fuel to the filter housing. My oil pressure is very good and I have the correct amount of oil in the engine. I have checked the fuses and they are good. Is there anything that I have not checked that I should? I do not have a scanner. |
Welcome to the ORG.!Have you checked the fuel pump? |
Thanks for the quick response, but I really am not sure where the fuel pump is, can you give me a little insight?
Welcome to the forum Jerry. Hope you get fixed up quick. Any moderator reading this, could you move it over to the 99-03 problems forum, it might help him get seen a little quicker. Good luck Jerry!
howdy and
![]() the fuel pump is on the driver side frame rail under the drivers door. |
Welcome to the Site!
Stick around, you will get some more help. |
WELCOME TO THE ORG!!
BUMP!!! Lets see if we can give this gentleman some help. Its over my head.
