power drain-help?
ive been tracing a power drain from somewere. ive rules out the alt,lights and amp. over nite i drop from 100% to 80% and sometimes lower.
what other things can cause a power draw? starter?after a couple days of sitting i cant start the truck. were else could i look for a issue? |
You can just try stuff, kinda hit & miss, the likely candidates have been the Radio, Instrument Cluster, Alternator. Unplug or pull a fuse one at a time maybe.
From there, you could just pull fuses in groups to try for a change. There is always the "Draw Test" where you monitor the amount of power the system is using, then pull a fuse at a time to direct you to the circuit that might be the problem (NOT as easy as it sounds.... ) Of course, many circuits are supposed to be consuming power all the time.If you have the time, it's far simpler to just "Pull & Wait" to see what happens..... |
