First cold day, no start? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-12-2007, 08:17 PM Thread Starter
It's friggin' September, and here in the most northern part of Minnesota, my 7.3 Dizzle would not start this morning.
2003 with 114k miles. Runs perfect, but had a tough time at 30 degrees. Would turn over, but not start. Just blew smoke out of the pipe. Bad gow plugs??? Injector??? First time it has done this, and it's only getting colder. Please help. Thanks.
MNDIZZLE is offline
post #2 of 12 Old 09-12-2007, 08:19 PM
cowboymafia's Avatar
Send a message via AIM to cowboymafia
have ya tryd putting any fuel additaves or plugging it up... not real sure but some one will get ya soon to help out...
1996 dodge 3500
the new toy
cowboymafia is offline
post #3 of 12 Old 09-12-2007, 08:19 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Hmm was it white smoke? Also are you batteries fully charged and up to snuff?
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #4 of 12 Old 09-12-2007, 09:07 PM
B4SouthernMiss22's Avatar
check your glow plug relay i had to replace mine last winter
2001 F-250 7.3. Garrett GTP38R ball bearing turbo, MBRP 4" exaust, muffler delete mod, Bully Dog 6 pos. chip, Edge CTS, 4" suspention lift, and moto metal 20's w/ 35/12.50/20 nitto Trail Grapplers
B4SouthernMiss22 is offline
post #5 of 12 Old 09-12-2007, 09:10 PM
if its a 99-03 7.3 it will be the short relay located in the valley of the motor in front of the fuel filter housing. reason i say short relay because there is one right beside it that is identical but is taller.
post #6 of 12 Old 09-13-2007, 02:18 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
check that and the batteries those would be my first suggestions
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 12 Old 09-13-2007, 05:58 AM Thread Starter
It was white smoke. The batteries and alternator were new last winter. After trying to crank it for a while, I did put the charger on it and then it started, but kind of rough.
Today it started, but also rough and blew white smoke for a bit, then cleaned up. Runs fine once it's going down the road.
So start with glow plug relay? Thanks guys!!!
MNDIZZLE is offline
post #8 of 12 Old 09-13-2007, 08:47 AM
vitalidle's Avatar
Yeah if your batteries aren't holding a charge they will crank the motor over, but you need 10.5 volts for the pcm in order for the truck to start.
Auto 93,000 miles
DP Tuner F5
post #9 of 12 Old 09-13-2007, 03:51 PM
Action Rick's Avatar
How about a new starter & some synthetic oil?.....
97 F350 4x4 Straight exaust ,performance injectors, 6 pos chip, 4" lift work truck
They say" most stuff is just stuck and need's hittin' with a hammer
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX
Action Rick is offline
post #10 of 12 Old 09-13-2007, 04:03 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
try plugging it in too.
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
