Help!! 1316 error code. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-10-2007, 09:25 AM Thread Starter
Send a message via AIM to Eric Preble
Changed CPS. Did not help. Cranks ok, then starts running rough. Any ideas???
Eric Preble is offline
post #2 of 2 Old 09-10-2007, 02:01 PM
Action Rick's Avatar
When it is running bad , unplug the valve cover plugs....One side will make very little difference in the way it runs...That is the bad side...Remove the cover & snap the UVCH plug back together..If it is not unpluged,, you may need a new UVCH... for that side,,,
97 F350 4x4 Straight exaust ,performance injectors, 6 pos chip, 4" lift work truck
They say" most stuff is just stuck and need's hittin' with a hammer
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX
Action Rick is offline
