Airbag light code 32 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-17-2011, 04:52 PM Thread Starter
airbag light is on... want to fix it i have read a little bit about this through the forum..... mostly talks about the clockspring. and then also about the horn. my horn works fine i do not have cruise control. i called the dealer and asked how much for a new one and was quoted 129 which i feel is high. they asked if i had cruise control etc.... are there different models? or will one online from parts bin for 30 bucks work?
99
7.3 CCLB working on 05 conversion
2005 350z coupe
US NAVY
Stationed in VA Beach, VA
tccurtis is offline
post #2 of 4 Old 12-21-2011, 09:53 AM Thread Starter
hmmm anybody?
99
2005 350z coupe
US NAVY
tccurtis is offline
post #3 of 4 Old 12-21-2011, 10:18 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I can't remember if the horn works through the clock spring or not, but if you're getting a 32 code then the clock spring is the issue. You can get them off Ebay. As long as you get one for your make and model, you'll be fine.
dhanna6powerstroke is offline
post #4 of 4 Old 12-21-2011, 10:22 AM
I do not have cruise or horn and air bag light is on. i was told by the dealer in 03' that the crash sensor is bad due to a wreck i had earlier that year.
I ended up wiring in a horn switch that you can get from a auto parts store for $3 to pass the safety inspection here in NC this year.
BRAD6160 is offline
