Started getting grinding noise, so that day i stopped by autozone and grabbed some cheapy duralast brake pads. Installed driver side flawlessly, and all was going well. On the passenger side front, the guide pin seized in the caliper bracket. Went and bought a new one... After installing that and throwing on those brake pads, i was still getting a grinding sound. Jacked up the truck again, and sure enough, the rotor looked like it needed some TLC. So back to autozone, and grabbed 2 new rotor/hub assemblys. Got home and put on the passenger side rotor, easy install and very simple, however, still grinding...
I've matched the caliper, there is no rubbing from that, when i replaced the guide pins in the bracket, i used the high temp silicone grease, and am sure those are not binding or seizing. Everything is tight, and i've visually checked that the brake pad clips are not rubbing when the brakes are pressed. I've greased the dam pads on the back side where they meet the caliper pistons, and have made sure the pads and the rotor itself where clean enough to eat off of, so no metal scoring... I'm still getting griding, and i'm about to lose my mind! Does anyone have any advice that might help out? It's my daily driver, and i don't like being that guy in bumper to bumper traffic with screaming wheels. |
I'm having the same problem on Duralast pads. I have a set of these on the way: Riffraff Diesel: EBC Yellow Stuff Pads - Front I've read some great reviews of how they perform on our trucks.
Found the problem, haha. It was the brake clip on the rear passenger side. Only found this out by a painful process of elimination. Turns out the bent part of the clip on the bottom side hiding under the caliper bracket was bent back somehow, still unsure, causing it to scratch alone the side of the rotor, and of course there was no wear pattern, because the rotor started eating away at the clip, not the other way around. Don't just look at the pads next time, sometimes these weird things happen.
Total cost of parts before i found the problem: 286.74 Cost of the brake clip: 3.38 (set of four) Fixing this problem: relieving! |
