truck wouldnt start again this morning=(!!! - Ford Powerstroke Diesel Forum
post #1 of 18 Old 12-13-2011, 06:05 AM Thread Starter
irishluck's Avatar
2003 ford f250
Went to go start the truck this morning. Had the block heater plugged in all night.
Unplugged it, went to go try to start the truck and nothing.
The batteries are good. They have charged and everything.
I have power since i put the key in the ignition and put it to accessory and the truck lights comes on not a problem, can here the fuel pump activate and such.
Then i go to move the key to full ignition to turn it on and nothing. There is a click noise in the engine compartment and then when i let the key ignition go it also makes a clicking sound.
Lights still work and all. Just makes clicking noise and wont start.
Would this maybe be my starter?
4" Diamond Eye Turbo Back, MBRP 4" Delete Pipe, 5% Tint
DIY Tymar Intake, Stancor MOD, GlowShift Pod Gauges
PHP Phoenix Performance Chip, 2" Leveling kit, BDS Shocks
Xtreme Motorcycle Parts
irishluck is offline
post #2 of 18 Old 12-13-2011, 06:38 AM
Quoted: 5 Post(s)
could also be relays, corroded connections, etc.
i would start by checking all fuses and relays
check battery cables and grounds for corrosion
does the wait to start light come on?
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 18 Old 12-13-2011, 06:48 AM Thread Starter
irishluck's Avatar
For the glow plugs? yes it comes on, all my lights work just perfectly fine.
The battery cables are fine, i looked at them yesterday, no corrosion and they are solidly connected.
What relays would i need to check?
Cause see i had this same problem about a month ago, it would randomly not start, then i would let it sit for a few minutes, and she would start right up. It did this for about a week. And now its happening again...
The only thing i notice is when i hit the key to turn it on to crank it, my mileage light goes away. (just to clarify, the digital mileage meter)
post #4 of 18 Old 12-13-2011, 07:13 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
This could absolutely be your starter.... BUT, could be other things too.
When it happens, I would hake a hammer to the starter itself. Give it a few good shots to reseat the Bendix and brushes. If that alone does the trick I'd think it was the starter. In the fusebox, in the cab, there is a relay that is your starter relay it could be that too. There's actually a fuse there too that's for the starter (like 113 - maybe?) Also take a real good look at all the starter connections, wiggle them to be sure they're tight and clean (this all assumes your battery connections are, as you say, good). With the cover off the fusebox use your hand to identify if the clicking is coming from a relay there.
In your previous post, we talked about the NSSW - you eliminated that - right?
NoRalPh is offline
post #5 of 18 Old 12-13-2011, 08:02 AM Thread Starter
irishluck's Avatar
The Neutral Safety Switch? Well as you said before, and i think this is what you meant, I tried wiggling the shifter and still wouldn't start, also tried to start in the different gears and still nothing.
Now i know you were helping me before in the other post i had. and that relay problem. Before when this happened and wouldn't start i would unplug the relay and plug it back in and it would start.
Heres the post with those images.
Random relay with wired under steering wheel fuse panel?
The brown wire that was soldered to a fuse, i re routed it to the above relay plug and put a crimp on it and shoved it in there, i would take that brown wire out and put it back in and my truck would start on the days this happened.
BUT, when this happened before there was no clicking noises like there is this time, and i can hear clicking noise this time.
I know there coming from the engine compartment cause i had my ear down to the fuse panel under the steering wheel and heard nothing, and had the hood opened and could hear it quite loudly.
Sooo what are your thoughts on this now...=/
post #6 of 18 Old 12-13-2011, 08:14 AM
Quoted: 157 Post(s)
Could the noise you hear under the hood actually be coming from the starter? Have somebody try to start while you're under there with your hand on the starter to see (don't forget the hammer ) .
And yes, NSSW = Neutral Safety SW, and when it's the problem you usually don't get the "click" when you spring the key forward...
I'm afraid I don't know if the Delayed Accessory Relay can give you symptoms you're having, doesn't "feel" like it should,,,, do you have an Alarm System in your truck?
NoRalPh is offline
post #7 of 18 Old 12-13-2011, 08:36 AM Thread Starter
irishluck's Avatar
You know it vary well could be, ill have to get under the truck and have someone start it for me and see if that is where the noise is coming from.
If it is, there thats where the hammer comes in play, and then thats when i replace it!
post #8 of 18 Old 12-13-2011, 02:38 PM
Is this a automatic or manual, if it is a auto it sounds like you are not all the way in park, there is linkage under dash that has some bolts that come loose and not let go all the way in park, had same problem
gwgnc is offline
post #9 of 18 Old 12-13-2011, 05:11 PM Thread Starter
irishluck's Avatar
ITs an auto. Ill check that but idk.
Guys im baffled (sigh)
The starter was getting the right amount of volts. Batteries are charged. no corrosion anywhere.
This is what i did.
I literately pulled all the fused out from under the steering column and put them back in to see if they were blew, none were blew.
I tried to start it again and it started this time!
Why would it do this? Im straight baffled
post #10 of 18 Old 12-19-2011, 05:08 PM
corrosion on one of the fuses??
chris'2000psd is offline
