weird noise driver side front wheel - Ford Powerstroke Diesel Forum
Old 09-04-2007, 07:36 AM
I have had problems with the driver side front before...
Situation: I am going about 10- 20 mph over a ditch and the front left side wheel goes in the ditch and out and when it is moving up out of the bounce of the ditch it makes this "boop" sort of sound. Like a vibration.
wtf now what do i have. hope its an easy fix.
Old 09-04-2007, 06:22 PM
It could either be your shocks or your sway bar bushings. It could also be your hub bearing going out.
Old 09-04-2007, 09:18 PM
just replaced the hub bearing... how do i check the others the best way
Old 09-04-2007, 09:23 PM
could be the tire rubbing on your bumper or fender... also give all the rubber bushings in your front end a good shot of wd40 that will cure allot of funky front end noises
