I killed it
Hello gents, I need some urgent help. I was workin on my 01 7.3 with it running, had the ebps unplugged and accidentally touched 12v power to the connector. It instantly killed my truck, now it won't start and AE will not connect. It just rolls over and won't start, and I get no wait to start light. Need help guys!!!
I have checked all fuses and found none blown.
Did you go through all of your fuses first to see if you blew any? Start small and simple. Always check fuses if you short something. They should be the first to fail, but no guarantee.
Late post. Sorry.
You checked all inside the cab and under the hood?
99% of the time, it IS a fuse somewhere.....
Your PCM isn't running, chances are, it's because it's unpowered, Fuse is the most likely reason. Go over them all again, maybe use a test light on both sides, check #30-19-22 especially. |
Yea, everything I could find.
You might pull them all out one at a time and inspect them that way. Disconnect your batteries first.
Checked both banks of fuses again, and again. Nothin.
Checked all the fuses with my multi meter and everything was good. Are there any fuses any place else? Think I may have fried the ECM?
