Not starting - Ford Powerstroke Diesel Forum
Old 11-24-2011, 05:27 PM
Not starting
So i went to start my cold truck. It cranked a bit and then no more power. I boosted it and it started up. i drove it around a bit and when i got back home i tried to restart it and it cranked a few times but went dead again. Batteries?
Update
Ok so now i went to try boosting the truck again and the truck wont start. It just continuously turns over but doesn't start
Old 11-25-2011, 05:36 PM
updatedddddddddddd
Old 11-25-2011, 08:20 PM
Johnny Law Brown
Did you check your oil and the fuel level sometimes the gauges quit working
Old 11-25-2011, 10:11 PM
Is it spinning over fast? These engines need to spin at atleast 150rpm before it will fire.
Old 11-26-2011, 02:27 PM
oil is good. there is about half a tank of fuel. it seems to me when its hooked up with the booster cables its spinning more than enough.
Old 11-27-2011, 06:01 AM
Ok i hooked it up again and this time it started fine. i drove it a bit and i dont know if these lights just came on or were on since i started driving but the wait to start glow plugs light was on and the the one above it i believe "water in fuel" when i shutoff the truck they idnt come back on. truck started fine a few more times but this morning barely enough power to crank anymore.
Old 11-27-2011, 11:02 AM
Johnny Law Brown
Sounds like its time for new batts, alt, or both
Old 11-27-2011, 12:04 PM
Just got 2 kirkland batteries from costo. 850CCA The ones in the truck were motorcrafts (probably originals - 750CCA). The truckstarted right up and turns over noticeably quicker than im used to.
