Sticky Front Brake - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-18-2011, 11:05 AM Thread Starter
Wert's Avatar
Sticky Front Brake
My front right brake caliper is sticking on and off. Planning on looking at it this weekend, considering just replacing the caliper. Any thing I should check specifically before I buy new front calipers?
Wert is offline
post #2 of 9 Old 11-18-2011, 11:08 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Check the caliper and hose
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 9 Old 11-18-2011, 11:16 AM Thread Starter
Wert's Avatar
Never dealt with this before, what am I looking for?
Wert is offline
post #4 of 9 Old 11-18-2011, 04:32 PM Thread Starter
Wert's Avatar
When I disconnected the line from the caliper, brake fluid started dripping immediately, and the caliper remains stuck. So I am guessing the brake line is fine, the rubber portion of the hose looks good.
Any tips for getting the stuck caliper off?
Wert is offline
post #5 of 9 Old 11-18-2011, 04:48 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You're slide pins are stuck. Possibly rusty.
Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 9 Old 11-18-2011, 04:57 PM
Bend6.0's Avatar
X2. Try pulling them out, cleaning the rust off if there is any, greasing them up
and putting them back in. I had to do this on my '01.
'03 F350 CCSB 27k
6spd,SCT Livewire
285/75/16 +2"front
RCD EGR Delete,AEM Intake
Sold:
'06 F350 CCSB 87K
6spd 4x4manual hubs
6"Fabtech w/35"s
'01 Stroke CCSB 112k 6spd
5" lift, 35" tires 4" straight
NAPA 6637 Intake, Wicked Wheel
TS T6 Pyro/Boost Gauges
AIH/EBPV Delete
2005 6.0, 2001 7.3, 2-'99, '97,'96,'95,'92IDI, 3-Cummins
Bend6.0 is offline
post #7 of 9 Old 11-18-2011, 04:59 PM
jesilvas's Avatar
Quoted: 2 Post(s)
And might need to replace the boot if it's torn.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 9 Old 11-18-2011, 05:29 PM Thread Starter
Wert's Avatar
Thanks for the link, I'll be working on this in the morning... I'll let you know how it turns out.
Wert is offline
post #9 of 9 Old 11-19-2011, 04:40 PM Thread Starter
Wert's Avatar
Ended up just replacing the calipers this morning and finshed bleeding the system this evening... Everything feels like new!
Wert is offline
