7.3 starts then wont start when warm problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-15-2011, 09:51 AM Thread Starter
Hello can any one help with this problem , drove a 7.3 1995 550 miles to France starting and stopping with no problems at all , im in England by the way. took it on a ferry drove another 100 miles parked it up went to move it would not start . Next day went to it it started , switched it off it wouldn't start again, it now starts once a day when cold when its started it will drive for ever without stopping its only when switched off it will not start. What has been to do it since is a new camshaft sensor replaced no difference to it.checked for air lock in fuel tank that's ok.tried the gear change lever that's ok. took it to a garage in France they looked at it got it started 15 times by messing around under the dashboard i took it away again the same thing happened started wont start when warm. the garage said bring it back we will have a look at it its been there 3 weeks now they said they need a wiring diagram , it does not have seemed to moved in 3 weeks ,can any one help me source one please , the problem is im English and do not speak French so its a problem as they dont fully know what im saying and vice versa but this would help out a lot , and has any one else had this problem econline powerstroke 7.3 1995 350 its on a camper Fleetwood Tioga Kind regards Dave
davecando is offline
post #2 of 4 Old 11-21-2011, 08:51 AM
By no start do you mean it will crank and not start or ot will not do anything when you turn the key?
late 99' F350, Crew cab, SRW, 4guage pillar pod, combo driving/fog lights, 55w backup lights, drivers side battery isolation mod,6637 intake
coot1 is offline
post #3 of 4 Old 11-21-2011, 07:06 PM
Land Yatch Driver
gygers's Avatar
I had similar problems this summer with a crank but no start condition after the engine was warm. I finally took it to the diesel shop and it turns out it was the ICPR (ignition control pressure regulator). Hope this helps.
Steve
2002 7.3L F350 Lariat 4X4 CC LWB
Auto tranny
ISSPRO Gauges
K&N CAI
Zoodad mod
Tru-cool 40K trans cooler
Walker Big Truck Muffler
gygers is offline
post #4 of 4 Old 11-23-2011, 07:56 PM
I just bought a beat up 2001 F250 with less miles (103,000) than my 99 but in way worse shape. The previous owner couldn't make it run. I got it started but after I run it a bit it will not restart. It will not crank. If I turn the key on and run a jumper from the battery to the wire going to the starter solenoid it will crank and start. Not wanting to spend alot of time troubleshooting this issue I just ran a wire from the battery to a switch on the dash and then to a relay that i wired to put power directly from the battery to the starter solenoid wire. Now if it doesn't crank when I turn the key I just push this button and I'm off and running,
coot1 is offline
