severely limited turning radius - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-15-2011, 08:25 AM Thread Starter
02PowerStrokeFord's Avatar
I recently had a blow out and my truck skidded the wall at about 70. Luckily my front and rear ranch hands took most of the damage. However my turning radius is very strange. It is limited by about 50 percent but the side that is effected seems to alternate. One minute I can't turn right then I can turn right fine but then I can't turn left.
none of the steering linkages are bent. Any ideas?
1999 350 4X4 6SPD
1997 F350 4X4 4Door Long Bed 35" BFG's
Stock Except For Front 35 Spline Kit with Lincoln Locker
350,000 and still tickin
02PowerStrokeFord is offline
post #2 of 7 Old 11-15-2011, 08:43 AM
SuperCrutyPS's Avatar
Quoted: 333 Post(s)
Garage
Have you checked your PS fluid level? Maybe your steering gear box?
May be jack up the front, have someone run the steering wheel back and forth while you check everything out??
Just offering some suggestions I would try. Good luck....
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 7 Old 11-16-2011, 03:31 AM
Johnny Law Brown
jc82chevyman's Avatar
I would say that kinda force most like destroyed a gear in ps box causing to skip a tooth or bind up(no turning)
2002 F-250 IH 444E
AFE Stage II
GTP38R
4" TB exhaust
35" BF Goodies
1995 F-250 IH 444E
jc82chevyman is offline
post #4 of 7 Old 12-06-2011, 01:45 PM
This doesn't really coincide with running into the wall but I had a similar problem when my front knuckle u-joint finally locked up.
bcvickers is offline
post #5 of 7 Old 12-06-2011, 07:12 PM
Quoted: 3 Post(s)
Put the front end on stands and check all linkage for binding or something bent. Spin your axle u joints by hand to check they are free. Then work the wheel back and forth if nothing seems out of line in the linkage its prolly the steering box.
2014 6.7 CCSB F-250 XLT 4X4, TUXEDO BLACK
SOLD:
2003 7.3 STD CAB F-350 XLT, BLACK
4" PRO COMP W/ BILSTEIN SHOCKS
35X12:50 PRO COMP EXTREME A/T
16X10 CEPEK DC-2
DP-TUNER F5 7 POS
ARB FRONT BUMPER & 15,000LB WARN
IraqvetUSMC is offline
post #6 of 7 Old 06-19-2012, 06:18 PM Thread Starter
It has been a while since I posted this problem, but I still thought it might help somebody to know what solved my problem if this thread is ever run across again. As some one else mentioned it was indeed a broken tooth inside of the gear box. There were no visible problems so the only way to diagnose reliably was to pull the box.
post #7 of 7 Old 06-23-2012, 08:36 PM
I had the same problem mine was from my steering stabilizer and bracket where both bent.
dirtcheap02 is offline
