Start & Stumble Please Help!
Hey Guys,
Ive got a 2000 F350, went to start it this morning, the cycled the WTS light fired it up she fired up but quickly went to a studder and then shut down. Tryed again. nothing. Gave it a couple minutes tryed again fired back up but repeated itself, started to studder and shut down. Any ideas where to start? Thanks!! |
If you don't have a SES light, think Fuel Delivery (pump/filter/inertia sw/low in tank)
If you do, there are just So Many things it could be you should get a scan if you can... Give the IPR sensor a look to be sure the nut & coil are there, you can try unplugging the ICP sensor as a test to see if it runs maybe. Ooops, I forgot my "usual" questions.... Tach Movement? - does the tach needle move up slightly when cranking? Fuel - pump runs? Fuel refilling filter housing? Tank below 1/4? (open the drain level to check) Is your truck "chipped"? If so, remove it as a Test.
