brake problem? - Ford Powerstroke Diesel Forum
Old 08-31-2007, 04:57 PM
brake problem?
every once in a while, When go to step on the brakes, the pedel barly moves and you have to really stand on it to stop. It has been happening more often now. Alot of the times it acts normal. Vac pump?
Thanks in advance
Anthony
Old 09-01-2007, 07:48 PM
BUMP anyone?
Old 09-03-2007, 04:26 PM
I hope someone comes along because I am looking for the same informantion..
Old 09-03-2007, 08:51 PM
Bump to the top .....
Old 09-04-2007, 07:33 AM
abs working ?
recently got brakes changed and new brake fluid?
might be air in the system, vac pump yes, how are your roters and brake pads
Old 09-04-2007, 07:38 AM
ADMIN AND TECH
not enough vacuum to the booster, yes probably vacuum pump
Old 09-04-2007, 07:44 AM
Jon
Guest
Posts: n/a
What
Scuffy, I thought that diesels didnt have vacuum? Ha Ha JK
Old 09-04-2007, 07:47 AM
ADMIN AND TECH
thats why you are a bad man in training :censord:a$$
Old 09-04-2007, 09:48 AM
Powerstroke Techie
I thought the brake booster worked off the power steering pump?
Old 09-04-2007, 11:40 AM
ADMIN AND TECH
it does 99-03 , hes asking about a 96 model
