Very Frustrated...Vibration Need help
Hello,
I have searched and searched for a solution and haven't had any luck. I'm getting a vibration in the steering wheel around 30-35 mph and then a major vibration at 40 mph. It goes away if I let off of the gas or put car in neutral. What I have done and had no success: Changed: U joints carrier bearing balanced driveshaft I'm tired of spending money and not gettting anywhere. Anyone have any suggestions? I have a 1800 mile trip coming up in a few days and I;m clueless. -Matt 1999 F450 2x4 Last edited by yobie; 11-10-2011 at 03:50 PM. |
My first thought is to have the front tires balanced.
i thought i saw somewhere about the power steering pump being the culprit....
I will check into the power steering pump. Could it also be torque converter related. Also its not a tire issue
Sounds like someone didn't balance the drive shaft properly. If it goes away after you let off the gas or put it in neutral, its not the tires.
Could be a host of things, and this one may seem far fetched, but I have had it happen. Check your bearings on the rear axle.
I feel your frustration.
I have been chasing the same ghost for a while. In addition to your list I have gone through Brakes rotors and calipers, replaced both front auto hubs with manual, both front hub bearings or needle bearings, Tires. I also thought rear axel bearings, but a friend suggested that if those were going there would be other signs such as leaks to tell, and that the problem would have gotten a lot worse with the miles I have put on it. I had the rear diff cover removed and drained just to check. My vibration is around 35-40 and then 65-70. Mine is now also accompanied by a sound that is like a dragging break sound,that was the reason for all the brake work. I can not tell where it is comming from. I also notice a slight almost shutter when the truck shifts from second to third. So if its transmition I just have to wait till something goes. The last suggestion I got from someone is the pinion bearing. I have not had that checked yet. |
If you still havent had any luck check the seals that get pressed onto the front spindles. I had the same problem for the longest time and that fixed it. Even with new manual hubs my front axle still had the vibration until i replaced the spindle seals.
how do you know if they are bad or go about checking them? thanks for the imput im still having this issue
