motor just stopped - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-10-2011, 06:04 AM Thread Starter
motor just stopped
I just left for work and on the way the motor just stopped running as if I turned off the key. It turns over but will not start. The only difference i notice is the Wait to Start light does not come on when I turn the key on. Any ideas would be great as I am stuck on the side of the road. Thanks
early 99 250 Lariat s/c s/b 4x4
DIY intake
4" MBRP turbo back straight w/ 5" tip
3 piller gauges- boost, pyro,trans
TW tuned -
stock, h/idle, econ, L-tow, H-tow, extreme
t/c lock switch
HPX line
regulated fuel return
warn hubs
cbremodel is offline
post #2 of 7 Old 11-10-2011, 06:30 AM Thread Starter
any ideas at all?
DIY intake
TW tuned -
t/c lock switch
HPX line
warn hubs
post #3 of 7 Old 11-10-2011, 07:22 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Sure your fuel heater in the bottom of the filter housing is shorted and has blown fuse #30 which also supplies the PCM.
Replace the fuse, unplug the heater, and you're good-to-go! You can then choose to either replace that heater element or just leave it unplugged as Many do. I doubt you'd miss it
edit: I just notices you're an early '99, might be #22 under the hood for you...
NoRalPh is offline
post #4 of 7 Old 11-10-2011, 07:35 AM
Mikey's250's Avatar
It might also be something as simple as your chip has come lose. Mine did the same thing a while back.
Michael- Georgia Powerstroke Diesel Association
2002 F-250 ECSB 4X4 Lariat
Mikey's250 is offline
post #5 of 7 Old 11-10-2011, 07:46 AM Thread Starter
thanks so much for the info. I will check both
DIY intake
TW tuned -
t/c lock switch
HPX line
warn hubs
post #6 of 7 Old 11-10-2011, 08:57 AM
Quoted: 133 Post(s)
In any case the lack of a WTS light in an indication your computer isn't running...
A fuse, or a bad connection to your chip (thx Mike ), is the most likely problem.
NoRalPh is offline
post #7 of 7 Old 11-10-2011, 01:12 PM Thread Starter
Smile
you were 100% correct. #30 fuse blown. I did as you said and was back on the road. Saved a half days pay. Thanks so much. This is why I love this site so much. Thanks again, Chris.
DIY intake
TW tuned -
t/c lock switch
HPX line
warn hubs
