Throttle Problems
2002 F250 with 215K, tymar, zoodad, straight 3.5" exhaust with dynomax bullet, diablo 85hp tune
Sometimes i will start the truck and the check engine light comes on. When this happens, the throttle doesn't work at all. I have had instances where the light was off and the throttle didn't work either. I noticed yesterday if i pick up the back of the pedal a little, the check engine light comes on and the throttle quits working. i let it back down and after a few seconds the light goes off and the throttle starts working again. i don't want to start a seperate thread so here is the other problem. every morning when i start the truck, it puffs white smoke and chuggs a little rough. it will puff for a few minutes if you let it idle but if you get on the road and floor it, it billows white and black smoke for a few seconds and then all is well. no smoke and it runs great. |
I dont know about the throttle but the white smoke is either your glow plugs or glow plug relay are bad.
![]() ![]() As for the throttle issue...think about changing out the accelerator assy. (gas pedal) That should get you going. |
slapped in a new throttle assembly today and its working GREAT. The last numbers on the part number are CA and the one that was in there was a BA. I did notice the sensor housing is MUCH bigger on the new one and the return spring is internal. I also installed a new cps since the price from ford dropped to 27 bux a pop. I actually replaced it and bought another spare just in case.
The truck has a new glow-plug relay but if its just a glow plug problem then i'm not too too worried. Thanks for the help! |
