droping boost and falling on its face? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-08-2011, 09:49 AM Thread Starter
harman99stroker's Avatar
i have a 99.5 f250 had the truck awhile no problem until now at a light cruise like 5 or 6 psi of boost with constant pedal its like the waste gate opens and i loose all boost and the truck falls on its face u get more pedal boost jumps up and u go you can hear i bad whooshin sound when it does this ....and now its doing it in 4x4 low offroad hillclimbing just its doing it up to 15 psi of boost.....when it does it u got to come off the pedal and stab it again .....is it the waste gate getting weak and doing this or what
harman99stroker is offline
post #2 of 14 Old 12-11-2011, 02:22 AM
same problem
I am having the same problem with mine however mine is not in as advanced stages, however it gets worse every time I drive it.
Goldstud is offline
post #3 of 14 Old 12-11-2011, 10:28 PM Thread Starter
I do think i know the problem though the rubber boot that connects the vaccum line to the waste gate is looking pretty dry rotten i have been meaning to find a new one and replace it to see if it sovles the problem ....maybe the boot leaks and loses vaccum and causes the problem
post #4 of 14 Old 12-12-2011, 06:13 AM
I am having the same problem. I can only build like 14psi and it makes that wooshing sound like all the boost is dumping out. From what I have read so far I think it is a weak wastegate actuator not letting me build any boost. I think I am going to order a new one this week.
Lando302 is offline
post #5 of 14 Old 12-12-2011, 06:44 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
EBPV cycling.....Whats you OAT?
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #6 of 14 Old 12-12-2011, 07:01 AM
Plug the wastegate actuator line. This will eliminate the possibility that the wastegate is opening and you can continue to run that way. Wont hurt a thing--stack turbo will not overboost the engine--most wont even hit the fuel cutback point up around 20/22psi. I have never had a vacuum line on my wastegate in 160,000 miles. Do not introduce a leak in the line at the wastegate. While this will delay the cutback it also robs vacuum also used to actuate your hubs on some trucks.
roaddogjru is offline
post #7 of 14 Old 12-12-2011, 05:21 PM
Think I am going to try this. Turbos didn't used to have a waste gate anyway. They only did that for EPA reasons.
Goldstud is offline
post #8 of 14 Old 12-14-2011, 08:43 PM
Still loosing boost, likley out the waste gate.
Well shoot. I sure thought I had the problem cured. I disconnected the vacuum line to the actuator for the waste gate, drive my truck all over the place and had no problems with it. Then on my way home from a meeting in town , I was no more than 5 miles from my house when it started it again. So something other than the actuator is opening the waste gate.
One thing that I have noticed, is that it does it more when the outside temperature is cold, like below freezing. It still does it some when warm outside, but not as much and it does not COMPLETELY dump all boost like it does when it is cold outside. Maybe something mediated with colder weather. I don't remember it ever doing this during the summer, but I had it do it just a bit last winter, though it was never dumping enough to notice more than just a hiss from the waste gate and no noticeable power loss as it would stop soon as I gave it more throttle.
Another thing, I am not sure my truck has a thermostat in it. I got this truck used with 76K on it. The temp gauge almost never gets more than about 1/6 of the way off the cold mark, even in the summer at 100 plus degrees outside. I rarely see it near the half way mark unless I am hauling a heavy load (like 15K or more) up a LONG hill. Everyone I know with the same basic truck as mine, the temp gauge reads about half way all the time. Any thoughts on on if there is a sensor that might be saying the truck is cold and opening the waste gate. Is there any way for it to open the waste gate with the actuator line disconnected??? What holds it closed, a spring?
Thanks everyone.
Goldstud is offline
post #9 of 14 Old 12-14-2011, 09:15 PM
If your coolant is not getting warm enough your oil temp can not reach the proper temp either and could be triggering the exhaust back pressure to close the flap on the exhaust.
You will loose power when the ebp valve closes.
I would replace the thermostat then take it out for a drive it should fix the problem.
You may get better mileage too once your temp reads right.
When the ebpv closes it sounds like a jet engine if you are near the tail pipe.
mgassel is offline
post #10 of 14 Old 12-15-2011, 08:01 AM
Thanks, I will try this next. Have to wait till the weekend when I have time but I hope that is the case. I know a lot of people that think an engine doesn't need a thermostat and they take it out. I have thought since the day I got this truck that, that could be the case with it, but have never ventured to take it apart to find out. I'll post my results after the weekend.
Thanks again everyone.
Goldstud is offline
