Clock Spring..? - Ford Powerstroke Diesel Forum
Old 08-28-2007, 11:50 AM
Clock Spring..?
When I baught my truck the airbag light would flash when I started then stay on. A few weeks later my horn stoped working, I can hear the relay click when I push it and I checked the fuses. Someone said it might be the clock spring, I have no idea what that is and how to fix it?
Old 08-28-2007, 11:53 AM
Thats Mr. Oil Leak.....
if the relay is clicking I would think it is the horn itself. The clock spring is in the steering column and you have to remove the steering wheel to fix it I believe. That might be causing the airbag light and horn but i'm not sure
Old 08-28-2007, 07:12 PM
Feedback Score: 3 reviews
the clock spring IS behind the steering wheel and can be replaced in the driveway if done properly... And the clock spring is the #1 cause of your problem diagnosing over the internet.. if you have a test light, you can check the horn connector to see if you are getting power.. with the help of soemone else of coarse.
