7.3l fuel pump location - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-01-2011, 10:30 AM Thread Starter
usnavyad's Avatar
Feedback Score: 3 reviews
Hey yall just out if curiosity where is the fuel pump on a 7.3l. Does anyone have a fuel digram i fallowed the fuel from the tank up to the canister then from there it went over by the relays and i lose it lookes like its in the head lol wtf thanks guys.
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #2 of 11 Old 10-01-2011, 10:38 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Under driver's seat, inside frame rail.
Bigger line leaves fuel tank, down the frame rail, into pump, up the front of the motor on driver side to fuel bowl, then out to either head or back through FPR to the tank.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 11 Old 10-01-2011, 10:39 AM
Buffalo444's Avatar
what he said. that canister is your fuel pump
Jason
First rig: e99 F250 CCSB 4x4 auto, white, 388k miles: traded in
Then: 02 F350 RCLB SRW 4x4 zf6, silver, 201k miles, THREW A ROD
: traded to Jake
Now: 96 F350 CCLB DRW 4x2 auto, red and silver/grey, 266k miles: rusty but trusty
Buffalo444 is offline
post #4 of 11 Old 10-01-2011, 10:40 AM Thread Starter
usnavyad's Avatar
I thought that was just an electric lift pump fuel pumps are normally engine driven
GPDA's other shawn
usnavyad is offline
post #5 of 11 Old 10-01-2011, 10:41 AM Thread Starter
usnavyad's Avatar
Hmmmm is it just me or is that weird
GPDA's other shawn
usnavyad is offline
post #6 of 11 Old 10-01-2011, 10:42 AM
Buffalo444's Avatar
nope. return is regulated at the fuel bowl. engine driven fuel pump is an OBS thing. if you're thinkin of an injection pump.... you're thinkin of the wrong kinda injection system.
Jason
: traded to Jake
post #7 of 11 Old 10-01-2011, 10:43 AM
Buffalo444's Avatar
it's just you. lol
Jason
: traded to Jake
post #8 of 11 Old 10-01-2011, 10:47 AM Thread Starter
usnavyad's Avatar
Not only that but jerk pumps im used to a pln set up and a line fir each cyl yall got me on this on so pressure is the same on a rail that is constant at each injector right
GPDA's other shawn
usnavyad is offline
post #9 of 11 Old 10-01-2011, 10:53 AM
Buffalo444's Avatar
you are thinking of mechanical injection. Here's a read for you on how our injection system works.
How HEUI works and best to convert
you must be used to ag diesel or non CAT/7.3-6.0 diesels. Because it's our main advantage over other diesel of the time.
Jason
: traded to Jake
post #10 of 11 Old 10-01-2011, 11:07 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Yes, the pressure in each rail is theoretically the same. Usually not reality though.
Our fuel pumps lift and pressurize. There is no in tank pump. Just an assembly for the fuel level and pickup and return lines.
Read the HEUI article. It clears everything up.
4R100, 2wd
330,000 + miles
jesilvas is offline
