2000 f350 died. Help..
My dually will start. Kinda. Runs like he'll then dies. Fuel pump is running. Acting like it is starving for fuel when it does start. Has a php chip, diy intake, and exhaust. Any thoughts?
Take off chip first. Then try again.
Try scanning for any sort of codes. Otherwise it just shooting in the dark |
Little update.. Towtruck showed up and we took it over to the dealership. After we unloaded it, I tried to start it and it fired up. Ran really ruff so I put the pedal down. Smoothed out a lot but still not quite right. Could this be bad injectors?
It was doing the same thing with the chip out too. Left it at the dealership to get a diagnostic run on it. Guess we will see..
Could be injectors, ICP, many things. Wiring harnesses.
BAD UVC harness connection is a first guess. Good luck at the dealer, ouch!!!!
