Low Boost? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-28-2011, 04:12 PM Thread Starter
roccodart440's Avatar
Low Boost?
Truck is making very low if any boost depending on the TW tune i'm running. Trying to figure out what the issue is. Truck is driven daily. It makes power at least no drastic loss. Noticing a little higher EGT's but nothing crazy.
To give you a basline i've lost about 15-20psi in my heavy tow mode. i'm trying to narrow things down and not having much luck. Scanned it. Nothing major going on there. No lights on dash. No abnormal noises comming from the turbo.
??????? help me out here.
2005 350 SDSC 4x4 Auto 6.0h no
Mods
turbo back exhaust, EGR delete, GPS, DVD, MP3
Privacy glass
For now.............................
roccodart440 is offline
post #2 of 2 Old 09-28-2011, 04:34 PM
Quoted: 3 Post(s)
build a boost leak detector, and crawl under the truck with a flashlight and check the uppipes for soot
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
