AIR VENTS NOT BLOWING - Ford Powerstroke Diesel Forum
post #1 of 18 Old 08-23-2007, 02:27 PM Thread Starter
Powerstroke W/smoke's Avatar
Hey guys i got an 01 stroke and the vents do not blow air. the only vents that work is the defrost vents in the front by the windshield. Ford, for some dumb reason, replaced my heater core because they cliamed that would fix the issue. of course it didnt fix a thing so if pulled the truck from the shop and will fix it myslef...with some help lol
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
post #2 of 18 Old 08-23-2007, 02:30 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Its a vacuum leak thats whats causing the problem
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 18 Old 08-23-2007, 02:44 PM Thread Starter
has anyone else had this issue? if so then where should i start looking for leaks?
post #4 of 18 Old 08-23-2007, 02:56 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
look under the dash where the passenger's right foot would hit the kick panel. The actuator is there. Check the hose for leaks.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #5 of 18 Old 08-24-2007, 12:14 PM
Feedback Score: 3 reviews
Stop stop stop... there is a big issue with Super Duty trucks and the vacuum pump. Start the truck, turn on the air, open the hood and walk over to the passenger side. Behind the battery is the round vacuum reservior, and behind it is a small little pump...
Now, is it working? should be vibrating and humming? If not make sure it has power.. let us know from there.
Joel
01 Platinum Edition-330k miles
Swamps 6 Pos., 200/30 Hybrids, WW1, EBP delete, ARP Studs, 910 Springs, FRx, HPX, High Flow CVD Fittings, Smith Bros Pushrods, 4" Magnaflow Stainless, ITP Fooler, EGT/Boost/Trans gauges
Ford AIS, Cowl Hood, Shaved Tailgate, 6.0 paint to match TT Mirrors, 6.0 Tranny Cooler, BTS Valvebody & Accumulator Body, Transfer Flow 46 gal tank w/ harpoon mod, AirRide Bags, Billet Grille, 03 headlights/Corners, 6k HID kit, 08 diff cover, 08 tail lights
ProStarPony is offline
post #6 of 18 Old 08-24-2007, 01:32 PM Thread Starter
awesome thank you guys for the help ill check it out
post #7 of 18 Old 08-24-2007, 03:21 PM
Served Our Country!
HighOn20s's Avatar
Send a message via AIM to HighOn20s Send a message via Yahoo to HighOn20s
OK Mine was doing the same thing... but would only blow out the vents on full blast.. the actuator went bad... $20 part.. mine in the 99 is located in the motor bay up in the corner of the passenger side.. some are under the glove box.
Replaced it in 15 min and it works like new. You will see a red backing and a plug.. 2 screws.
USMC 96-00/0311
If you don't stand behind our troops, please feel free to stand in front of them.
2008 F250 Supercrew, Custom 14'' 4-link, F.O.A 2.5 Coil overs, 40/15.5R22 Toyo MTs on Hostile 22x14 Wheels, Yukon Lockers/4.56 gears,
PSC Hydro kit, H&S Mini Maxx with KEM 345 Tune, S&B CAI, TurboSmart BOV, No Limit Fab IC, EGR Delete w/ CSP, MBRP 5' exhaust, AirDog II, TransferFlow Tank, Rigid Industries Lightning!.
HighOn20s is offline
post #8 of 18 Old 08-28-2007, 10:45 AM
zac
zac's Avatar
i am having the same prob with my 99. my vacum pump is still good so i have a wire issue somewhere between the pump and the switch.
zac is offline
post #9 of 18 Old 09-02-2007, 10:18 AM
If yours is a 4x4 check the vac. tubes at the hubs. Also check vacuum pump as mentioned earlier and check for leaks behind the glove compartment at the actuator. Defrost is the default position if something goes wrong....this is for safety reasons.
SQUIRT CAN is offline
post #10 of 18 Old 09-02-2007, 11:52 AM
OK I am having the exact issue, and I just got this truck. I think the acutator is missing by the last meat head that worked on it.....right by the passengers foot there is 4 vac lines that are molded into a little rubber harness- is this where the regulator is supposted to go?
Thanks
pcutrer is offline
