What The?
Hey gang SGT D forum newbie here i have a PSD problem. here's the breakdown.
Drove home for lunch no problem. Parked. Ate lunch 1 hr later i started truck, backed out of parking spot put truck in to drive and made it approx. 20 yards before i lost throttle response engine started running rough and then stalled out. Truck would crank and tried to fire over once again but now just cranks and cranks. I have recently replaced fuel/water sep. o-rings and fuel filter element. I run pump diesel and Power Services cetane booster. The fuel gauge shows a 1/4 tank of fuel and the fuel system pressurizes to the point that when i cracked the fuel filter lid to have a looksy it shot everywhere. HELP? |
Sounds like the typical CPS (Cam Position Sensor) may be bad.
no clue my friend, but im sure someone more knowledgable will speak up soon!! welcome to the site!!!
this is exactly what happened to mine lol. its a simple $15 fix if this is whats wrong
Welcome to the ORG!!! |
Ok i check it out. where exactly is the CPS located
Oh yeah - WELCOME
mine is a 7.3 and was located directly in front of the block.
also, if you search online im sure you can find the directions for removal and reinstalation with a new part.
thanks gang i found it
