Alright guys, new to the site and new to owning a diesel. Got a 01 Excursion 7.3. Its got a banks big hoss bundle (bigger IC, 4" exhaust, tuner, chip, trans shift, waste gate, pretty much everything but their intake)
I bought it this past Sunday. Drove fine, great power but I wasn't beating on it, always let it warm up and not really get into any boost until warmed up. Tuesday afternoon I went to fire it up and just crank crank crank Hooked scanner up and saw the cam sensor code Replaced it and it lit right up like a dream. Only problem is it only stayed running for about a minute then died. Wouldn't restart. Just cranks. While cranking I noticed the banks six gun tuner showed IPC (or is it ICP I'm not a 100% sure but its the sensor on the drivers side valve cover) error/fault Cleaned it out still nothing, unplugged, still nothing. Fuses are good. Batteries were replaced this morning and terminals cleaned, cranks a lot faster but still won't fire. Fuel filter seems clean, can hear the fuel pump come on. Fried pcm? Injection control Any help would be greatly appreciated. |
also, oil pressure gauge sometimes moves up to normal while cranking but have to be cranking for a few seconds, swapped the cam sensor for a new one thinking maybe it was a faulty sensor, nope still just cranks
look in your hpop resevoir, oil may me low due to leaking o rings or check valve is stuck. if oil is low it wont run. if it is low put oil in and it will fire up and run.
Checked the level it's pretty close to the top. Not on the threads but a bit below that
